Sammus
Sammus's Avatar
07.24.2008, 10:23 PM
I was just thinking. The mamba max says you can run 12 cell NiXx. I've had my nickel batteries at 1.5V off the charge before, 12*1.5V = 18V.
A123 is 3.6V at full charge, 5*3.6V = 18V.
So technically, it should work right? It must be within the design spec of the MM, even using the built in BEC...
