lutach
lutach's Avatar
07.25.2008, 11:57 PM
I always thought the Pletts were 4 pole, they even have P4 (poles 4?) in the part number. After running my big maxx on the MGM controller and looking at the peak rpm (when set for 4 pole), I get a max rpm of 78,000 on 6s (22.2 volts) in the software. If you convert that over for 6 pole, it would be 52,000 rpm. The big max is supposed to be 2300 kv, so 22.2 x 2300 = 51,060 rpm, which makes more sense and leads me to believe it IS actually a 6 pole motor.
The ones that use the P4 are 4 pole motors. Most of the Plettys are 6 poles.
