aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.31.2008, 01:30 PM
Originally Posted by TexasSP View Post
These should be the base rules in my opinion. I also think there should be a freestyle competition where anything goes though.
MT:
High ground clearance
6" or larger tires/No foams
Chassis built above diffs
Transmission
Truck or SUV body
No Sway bars
No wing
Minimum 12" Wheelbase
Truggy:
Chassis below diffs
5.5" or larger tires/foams acceptable
Center Diff/No tranny
Lower ground clearance
Truck or SUV body
Wings acceptable
Sway bars acceptable
I like this idea.. but maybe add/modify
M/T
Tire height should be 5.75"+ no foam
Tire width should be 3.8" + no foam
Tires has to outside of the body and fully exposed.
Chassis built above diffs and/or TVP
Has a Tranny (or center diff built inside a tranny or built above/higher than the front & rear diffs)
Truck, Jeep, Semi or SUV body
NO Sway bars
NO Wing
Minumum 13"+ wheel base.
TRUGGY
- rules looks pretty good to me..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
