cemetery gates
07.31.2008, 09:33 PM
I'd say it is heavier than a rustler. Converted .5's can range between 4.5-5lbs. Also, if it is a technical track, you might want to stick to a stock chassis because the shorter wheelbase will give you a tighter turning radius.
