ffactory666
08.01.2008, 05:15 AM
Originally Posted by mxracer View Post
i have no idea how the hell you get runtimes like that , this is my setup
neu 1512 2.d/f
hyper st pro truggy
52/12 gearing
mamba max , 15v cutoff voltage
5s flight power 4900mah
everything is pretty close to the same as yours , yet i get about 9-12 mins runtime
i have a jammin cr pro buggy , i will try replacate your setup as close as possible , but i very very much doubt i will gain another 30 mins of runtime
HOW DO U DO IT ??
You should be getting minimum 20 mins with the battery you are using.
Somehthing isn't right.
What temps are you getting ?
Your driveline might be binding some were causing drag and robbing you of run time .
Check your diffs , cvd's Centre front and rear ( especially the pins ) and bearings
