Thread: My BL Savage
E-Traxxer
08.02.2008, 04:40 AM
So, I have, for the most part, finished all of the basic drawings. Everything is blocky, and there are no holes placed yet, but everything is in place. I have run into a bit of a problem, though. I can fit on a rear brake on the center diff without any problems, but I will not be able to fit one on the front unless I extend the chassis another 20mm (40mm if I want equal weight distribution). The chassis is already extended 62mm longer than the FLM Extended TVPs, so I really don't want to extend it any more. So I am thinking about putting a brake on the output of the front diff. So the question is: does anyone know if there is an existing kit that will allow me to do this? I've done some searching around, but I have had no luck. If there is no kit, I can probably draw one up in Solidworks without too much difficulty, but that means that I'd have to wait longer to finish the drawings, because I'd have to order brakes and measure them and such.
Thanks!
Here are a few pictures of the basic layout for those interested, it's all just basic blocks right now, but I just want to get everything ligned up correctly before I do the holes/reduce the block-age. I personally like this layout much more, plus there's more power in it! I think tht this is just cleaner too, it was much easier to work with SW the second time. If you have any suggestions or anything strikes you as possibly a weak link, let me know.
Trimetric View:
Front View:
Side View:
View without the battery covers or gears (at least, the cylinders that take place of the gears):
And here is what I have for the speed calc, I can get anywhere from 10:1 to 25:1, so I have enough gearing options I think.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2.3636363636363636363636363636364
Other Ratio: 1
Spur Tooth Count: 38
Pinion Tooth Count: 17
Total Voltage: 44.4
Motor KV: 1150
Tire Diameter (inches): 6.9
Tire Ballooning (inches): 0
Motor Current Draw: 100
Motor coil Ω: 0
Spur/Pinion Ratio: 2.24 : 1
Total Ratio: 17.47594 : 1
Tire Circumference (inches): 21.68 inches (550.6 mm)
Total Motor Speed: 51060 RPM
Vehicle Speed: 59.98 mph (96.34 km/h)
Estimated Adjusted Speed: 55 mph (89 km/h) - 8% loss
Effective KV Value: 1150
KT constant: 1.18 oz-in/A
Motor Torque: 0.61 ft-lbs
Final Torque: 10.7 ft-lbs
Final Power: 4440 watts (6 HP)
