5s 1512 -
08.02.2008, 10:33 AM
I run a 1512 on 5s with a modded MM all the time. The main issue you will run into is getting the gearing low enough to avoid heat issues. The motor will want to spin much faster than the gearing will allow. I put truggy diffs in my buggy and it helped a lot.
