Originally Posted by BL_RV0
Here's what I gather about the good and bad om amps (very basic but typically true):
More amps: more power on less voltage, more heat, less runtime.
Less amps: same power on higher voltage as hi-amp low voltage setup, less heat, more runtime.
True, but we need to add battery capacity into the mix. Let go with 4S since that's what the racers are using. They'll need 5000mAh+ to get a 15 minute main done. With 6S you might need 3300mAh+ to get there. Now I'm going to try 8S and 10S and I might only need 2200-2600mAh.
