jnev
jnev's Avatar
08.03.2008, 01:17 AM
I wouldn't say there is a big chance of the MM frying with the 1515/1.5d, but that motor sure does pull a lot of amps from the battery. So I think that its the batteries that would be getting worked the most. As long as the ESC can handle the current, which the MM should be able to handle, it should be fine. The 1515/1y will give you better temps all around though so I'd stick with the 1y and sell the 1.5d if you don't need it.
