hoober
08.03.2008, 08:40 AM
As close as I can remember the first graph someone said took 18 minutes , the second one 8 minutes.
1st graph was claimed to be 126 amps , but was probably about 15 amps and 3.3C
2nd graph was claimed to be 60 amps , and probably is 60 amps. That is 7.5 C
delta for first graph was 20 deg F and 2nd was 50 deg F (125 deg F max) ]
The battery should really be able to be pulled a bit harder and will be a nice 12-15 C constant battery. It would be unrealistic to expect the full capacity at the full current. Full capacity shall be listed at very low current. sorry, that's the way it is.
