08.03.2008, 10:48 AM
This looks like something I would like to do to my e-revo.
The leg work you guys have done to figure out what works will help a lot of people who would like to try this.
I am curious, though, about the largest size pinion that you could fit on the motor shaft and still have it clear the inside of the aluminum motor mount. What have you found?
What top speed are you seeing with this setup?
What gearing are you running right now? It's a little unclear about which gearing causes the motor to heat up, etc...
Thanks for the help.
Karl
