jhautz
jhautz's Avatar
08.05.2008, 01:18 AM
Thats a hard question to answer exactly. I ran it before the mod mostly on the indoor track in the winter when it was much colder and got similar temps. This last weekend the modified esc got a pretty good workout and temped very well at only low to mid 150's with no fan after the 15 minute main. Thats pretty good even for the big escs I was ruinning. Edumakated was running his buggy in the same conditions on 4s rather than 5s and getting higher tmeps on his MMM without a fan. The 4s may have been harder on the esc than 5s as far as heat goes though so, if I had to compare it I would say it is at least as good as the MMM without a fan.
Not sure if that helps you or not.
Keep running it as is. If you have temp problems then have Artur mod it. He out of buisness for a bit right now anyway so you might as well run it. By the time he is ready to go again this thing will have been throught the paces a number of times and I should have a better long term assesment. So far its has been stellar for 2 race days. I still havent been to my regular track with it though so that will give me a better sense of how it performs against the MMM.
to make it...
or break it...
Silent...But Deadly
