TexasSP
Something, anything, nothing
TexasSP's Avatar
08.06.2008, 09:14 AM
You can play with it in the speed calculator to check for sure, but I think you may be able to use stock gearing and just go smaller spur/larger pinion to make up for it. The brushless motors have a little more capability than nitro.
Edit:
Here it is set up with a 1512 1.5d running 4s lipo and the Revo wide ration second gear. You could also sub the 50mm 3300 kv medusa in there as well.
Differential Ratio: 2.8461538461538463
Transmission Ratio: 2.111111111111111
Other Ratio: 1
Spur Tooth Count: 38
Pinion Tooth Count: 16
Total Voltage: 14.8
Motor KV: 3300
Tire Diameter (inches): 4.37
Tire Ballooning (inches): .5
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.38 : 1
Total Ratio: 14.2703 : 1
Tire Circumference (inches): 16.87 inches (428.51 mm)
Total Motor Speed: 48840 RPM
Vehicle Speed: 54.68 mph (87.83 km/h)
Estimated Adjusted Speed: 51 mph (81 km/h) - 7% loss
Effective KV Value: 3300
KT constant: 0.41 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
www.cubicle101.com
