08.07.2008, 08:30 AM
The Muggy is not the same chassis as the 8t. A brake spacer should allow you to utilize the mechanial brakes. If you use a single high torque servo for steering, you have a built in servo location for brakes - just need to bend some linkage to allow it to pull the brake levers. :)
