Thread: My BL Savage
E-Traxxer
08.07.2008, 09:12 AM
Originally Posted by bl-is-future View Post
oh forgot to tell you though that escalade body is the longest. That is the style on my truck link here - http://www3.towerhobbies.com/cgi-bin...2&I=LXPCG5&P=K some genesis bodies are shorter. Just look at the lengths to see how shorter.
Oh alright, thanks for the info.
I'm also going to post what I have for the speed calc now, mainly for my own records, since things tend to get lost on my hardrive... (It's those cyborg lawn gnomes with USB connections, I say!)
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2
Other Ratio: 1
Spur Tooth Count: 38
Pinion Tooth Count: 14
Total Voltage: 44.4
Motor KV: 1150
Tire Diameter (inches): 6.9
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.71 : 1
Total Ratio: 17.95604 : 1
Tire Circumference (inches): 21.68 inches (550.6 mm)
Total Motor Speed: 51060 RPM
Vehicle Speed: 58.37 mph (93.77 km/h)
Estimated Adjusted Speed: 54 mph (86 km/h) - 8% loss
Effective KV Value: 1150
KT constant: 1.18 oz-in/A
Hmm, I just found this body for the MGT http://www3.towerhobbies.com/cgi-bin...?&I=LXFUL9&P=7
It says it's 20 inches (shorter than the Cadillac for the Genesis) but also says its 556mm (longer than the Genesis one).
Hmm...
