MetalMan
MetalMan's Avatar
08.08.2008, 01:44 AM
Originally Posted by Shark413 View Post
Still experimenting with the brakes, I will turn the motor brake way down, disconnect the front mechanical (remove the servo 3rd channel wire from the rx) and run motor brake only, to see how it feels. I guess I will need to wait for the Ofna Hyper 9 before I can go with full mechanical brakes again. The Hyper 9 has the rear brake mounted at the rear diff so motor clearence won't be an issue. I have also been playing around with making a rear mechanical brake mount that works similar to the Hyper 9 that I could try out on my Kyosho's. Just not enough hours in the day.
Why wait for the Hyper 9?
http://www.rc-monster.com/forum/showthread.php?t=12295
