bustitup
08.08.2008, 12:43 PM
Thanks for the confidence Rootar......I also knew I was ok but do feel better since i called
anyway the 1515/2.5 has a 80 amp rating ....you guys think these batts would suffice?
NEW TrueRC 5000mAh 11.1V 3S1P 15C Pack
HIGH PERFORMANCE PACK FOR AIRPLANE OR CAR
Balance plug, works with all of our balancers. Can be modified for AF Blinky for use without adapter.
Size
28mm x 45mm x 160mm
Weight
395g / 13.9oz 12AWG WIRES
Discharge
Up to 75A Continuous
100A Max burst
Price
$89
Fits PERFECT into Traxxas E-REVO
with the L shaped bracket removed.
L shaped bracket is for holding down shorter packs and can be easily removed since this battery fully utilizes the battery bay. For best fit, install the battery into the bay with the wires first.
PERFECT FOR MMM or NEU motor setup and any other 6S capable ESC and Motor
