Originally Posted by lincpimp
Like the mugen plate? P/N ZMT-008. It fits the std diff cups and will allow the ofna 51t spur to bolt up.
Almost... but not quite,
The mugen diff uses 5mm shafts so it won't fit the Losi8 diff properly unless you make your own 5mm shaft mod. This could be done but I'd rather use standard 6mm shafts.
Also, the ZMT-008 is getting pretty hard to find these days
I've got 3 of them
