08.09.2008, 12:05 AM
Hey,I have an Ultra GTP with a Neu 1512 2.5d on 5s and it is a blast. It's a pretty tough car,only had to replace rear axles so far. I upgraded to cvds seems like a stronger/smoother setup.
Also you might want to consider foam tires as the rubber ones don't hold up to brushless if you stay on it alot.
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
