Just go Play
Just go Play's Avatar
08.10.2008, 02:42 AM
Originally Posted by ReV:-O View Post
woah if i can get 59mph and the motor is only spinning at 35000RPM, imagine how fast it could go with the 1515/1y spinning at 50000RPM!
Not sure if your serious or not but if so there is more to speed then high motor RPMs's. If that was all that mattered then you could just throw in a mamba 7700 and go even faster right?
1521's create more power and can be geared higher then is possible with the 1515 series motors. But if you really want the high rpms you could get the 1521 1D. More power then you'll be able to use, high rpm's, and certain to pull a ton of current in the process.
