glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.10.2008, 02:55 PM
Originally Posted by mk351e View Post
I started the thread about well, you know what. ok, done. then I come home from work yesterday, and in the mail is a package for me. then I look at the address, IT'S FROM CC!!!!!
So I bolt in the house like a loser and open it up, excited as hell! Later that night, I bust out the soldering iron, and get busy. around 3 am my batteries are all charged, and it's time to connect and calibrate. but, same issue as last time: can't get this thing to calibrate w/ my spektrum. I even bumped the arming time all the way up to 5 seconds this time! So I try it over and over again, maybe 7 or 8 times, then, I hear what sounds like a popped fuse, and it's game over.
I've checked my connections MANY times, but there aren't many, and this isn't rocket science. I've tried to go back and get it to work, but it's dead as a doornail, just like last time. I'll call CC tomorrow to see what we can do, but the deadline for them will be 8/15. If I can't get a working MMM by then, and I really do want THAT, then it's off to mgm I go, to spend a lot of extra money on a controller that I hope will work. If not, then i guess I need to go back to nitro.
I can say with total certainty that this hurt even more the second time around. Perhaps someday I can get through the calibration process with the MMM.
I'm wondering if you unplugged and replugged the battery a lot during this process?
I killed an LRP esc once because of a connector that was difficult to get plugged in. Once it took several trys to get it plugged in (caps charge and spark every time) and that's all it took to smoke it.
just a thought....
When exactly did this "pop" happen? When batts plugged in, switch turned on? During the calibration???
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
