traxxasrevony
08.11.2008, 12:04 PM
i think you should be fine i run a pro boat balckjack 26 with a hydra 120, 1515 1y (2200kv) on 4s with a grim racer 42-55 prop and speed controller temps are around 120 max, motor is about 120-130 and batts about 105. the one thing i suggjest you do is have 2 water pickups for the liquid cooling. most setups have one pickup and the cooling goes thru the motor then to the esc or vice versa. so either way the motor gets warm water off the esc or the esc gets warm water off the motor.
