kevin23
08.11.2008, 11:15 PM
well a little update,
I came across an 8ight really cheap and I had one of the tekno kits in stock at the store,so I converted the buggy using the neu.
I love this thing,geared with a 13 pinion it is really fast,a little to fast for the track,turned endpoint down to 75% with a 5s tp 25c 5000 pack.
I get 20min's runtime with temps for the motor 150-160,esc110-120,batt temps were 110-120.
Should I be concerned with the batt temps?cutoff is 16v.
I tried it on one of my 4s 25c tp 5000 batteries,had to turn endpoints back up to 100%,runtime was still 20min's same temps same gearing,was noticibly slower,but was manageable.
Should I get more runtime than I am?Would I get more runtime running 5s with 75% throttle or 4s 100% same gearing for both setups?
mm is setup lowest timing,low start power,50% punch control,12.4v for 4s 16v for 5s cutoff's
Thanks for any info,I will be posting pics as soon as I find my cable to transfer pics.
