Snipin_Willy
Snipin_Willy's Avatar
08.13.2008, 11:24 PM
Mamba Max came in today. That's one less part!
I have a bunch of 2.2 t2/t3/t4 wheels (pro-line velocity) that don't use a hex, but rather just a pin (1mm shorter than the CRT standard pins). But the inside spoke barely hit the suspension arms as they turn, is there a way to shim them out a bit to get them to clear or should I shave a bit off the suspension arms where they hit?
