08.15.2008, 04:26 PM
I'd say 12mm was too long really, though it depends on the thickness of that mounting adaptor. Tip: screw in the screws until you feel them touching somethng inside the motor- if there is any slack or exposed threads, you need to remove that much from the ends of the screws + another 1 or 2mm. Or use screws that are that much shorter.
