speedracer1129
08.16.2008, 10:38 PM
Hey Brian. I thought I would post some info of my first test runs with my converted Inferno GT so you can have an idea of possibilities.
- Feigao 7L
- MM ESC
- FP 4S 5000mah
- 21/44 gearing
- Ferrari body
We tested this setup on Wednesday night and it did quite well in my opinion. I am running 2 60mm fans, 1 for the motor and 1 for the ESC blowing right on them. No holes cut out in the body. The fans work GREAT!! They were from CompUSA for $5 each and are rated at 26CFM/12V. We maxed 71mph on the radar and easily got 10 minutes of bashing. I did not get to run it longer as I am using the RCM 2 speed adaptor and a Losi 2nd gear pinion but I did not think about putting on the 1st gear and I backed out the gear due to braking!! I think this car has the potential to push triple digits with as little as 6S!! The problem I see is getting the right body!!
They have the bodies here, but at one heck of a premium!!!!
http://www.deltaplastik.it/index.php...at2=11&cat3=15
