08.24.2008, 01:36 AM
FWIW, I've played with the settings on the TX as much as possible, the only thing I haven't done is reflash the firmware. I have a fasst, and it works fine with a SW. Several diff motors, same result.
The only other thing I haven't played w/ is the "ABS" settings. They should be default, but I'll check. The prop brakes seem to work perfect now I've just plugged a MMM in and changed nothing on the TX and loaded the saved CLink settings from the MM.
