08.24.2008, 06:05 PM
Originally Posted by edep345 View Post
actually, the 3spd, but if I DO plan to use these crap lipos, I guess I will need to convert back to 2spd, and yes mech brakes, 9xl motor. So you seem to be doing fine, is that because of the HUGE voltage? So basically I will have to run my flm ext sav x ss at 35-40 /w 2spd, mech brakes to ensure good performance with these lipos?
You can still use the 3spd, and will have to run mech brakes with either the 2sp or 3sp. The shifting mechanism uses a one way bearing, so motor brakes will not do anything. You may be able to run the savvy at a higher top speed, as the addl gear the 3 spd offers will help. Basically the lower gearing in 1st helps the motor draw less current (amps) as it lessens the load.
again, just a thought: sorry for my curiosity, but if I absolutely HAD to, should I make the savage 1speed for better runtimes/less stress on lips?
See the above answer... A single speed will place more load than a 2 or speed, assuming that they are all geared for the same top speed. Just imagine trying to get a manual trans car moving in 4th gear, as opposed to 1st...
Originally Posted by azjc View Post
IMO I would bite the bullet and buy better packs...it would be $50 you could spend towards a good pack, a 4s 5000 Zippy pack will be about $75....a 4s 5000 Enerland based pack is my first choice...I prefer flightpower
http://www.rc-monster.com/proddetail...P-EVO25-50004S
and Neu which are just as good and are a little cheaper
http://www.rc-monster.com/proddetail...eu25c4s5000car
Yes, better lipos are great, but he should be ok with the ones he listed. He will need to start out carefully, and monitor temps on the lipos to make sure his gearing is not too high. Start with a smaller pinion and do some testing. Outside air conditions will have some affect on temps too, a hot sunny day, 90f and up, will result in much higher temps than a cool autum evening...
