10.22.2005, 09:51 AM
The problem with the stock type drive shafts is clearance(too big diameter). The space is limited, so really a metal drive shaft is the only option. Anything larger would rub the steering parts in the front and the bulkheads in the rear(the rear would be close, but I am quite sure it will rub).
