10.22.2005, 05:19 PM
Yes, I use the gold bullet connectors for the motor/esc connection. One of the main reasons is that so many of the motors and controllers already have that type of connector already. For example, the Lehner xl4200 I bought here had 3.5mm bullet connectors on it already, so I just had to add 3.5mm bullet connectors to my MGM. The new-style MGM controllers have 3.5mm female connectors on the controller itself, so you need to put 3.5mm connectors on the end of the wires you plug in.
For me, it's a matter of convenience and reliability.
I suck at soldering, so I try to solder as little as possible :)
I love the standard 35 amp PowerPoles, by the way. They are the only connector I use now on batteries. I've been thinking about using the 45 amp inserts, but haven't tried them yet.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
