Mozzy
Mozzy's Avatar
08.30.2008, 05:04 AM
Is there anyone on here that has been running the same car as mk351e with a set up that doesn't over heat?
At least this way mk351e will see what works with others & understand a little more of his own set up & it's capabilities.
Now, when I was running my CRT with a Neu 2700, MM & 4S 6000mAh, 13t pinion everything else stock, the car would absolutely fly.
No wheelies at all & I was/am running a torsen centre diff (basically it's a locked diff when the front loses traction & makes it 50/50 split.)
It was blindingly fast, but(!), everything but the batteries ran cool.
By the end of the run the battery would be nudging 85 degrees C(!) on a coldish 15 degree C day with a runtime of a mere 5mins 50secs (I timed it).
How would reducing current help mk351e's temp probs?
I don't get some of this stuff at the best of times, so, this just makes it more confusing.
I'll be working for my friend now who's currently in Tawain, HK & China, securing contracts with companies to supply components for everything from nitro to BL.
I've also got alot of guy's interested in BL conversions, but, I'm at this stage limited with knowledge to be able to say, you need this, this, this & this & you'd be able to run reliably from day one for this purpose. Obviously, the setup & requirement of the person's use would vary & therefore so would the set up.
I treat you guy's like an encyclopedia of the BL world as I know it. I listen/read everyone's input then generally go for the most common answer. Thanks.
By the way, so far after my op I'm doing alright, very sore after have them saw through my sternum. I'll post pics of the clots that were removed from my lungs after the 12th Sept when I get back to Melbourne, I know you'll all be saying holy crap, cause, I certainly did! Just happy to be alive at this stage.
Long live BL & me!!
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
