Thread: tekin r1mt
lutach
lutach's Avatar
09.01.2008, 07:59 PM
Originally Posted by teamtekin View Post
I hear you Lutach and agree in some engineering respects. However the Rx8 uses 30v fets and will only be rated to 6s batteries. We are fairly confident that any racing rules will be based on 4s batteries and that will be the standard. Some may use up to 6s, but beyond that there are other factors to consider like the chargers that are commonly available. All of the manufacurers appear to be headed towards this range. If you want decent prices and good racing we have to settle somewhere common. It is not up to use and this just where it looks like we are going as a industry.
I know what you're saying. I just wish the industry actually knew the benefits of higher voltage. I can easily have a 10S or even a 12S set up that will have the same amount of power and run time as a 4S set up, but I'll be safer due to less AMPs used. Every thing will perform at a higher level of efficiency. I might be asking for too much, but is there any way you can make me a 10 or 12S capable ESC?
