Darion
Wink 09.02.2008, 12:27 AM
First off thanks for all the replies.
Good question.....I have an MGM 160 that works great....even runs cooler than the mmm.
Thanks for pointing me in that direction, looks like a damn fine ESC.
Originally Posted by DRIFT_BUGGY View Post
You could spend $20 and buy a ext. CC Bec (which is alot cheaper than another esc) and run the Ext. Bec off it until the problem has been worked out with the MMM.
If not, than could look at R1 Pro
Considered doing this but I'm not sure that the built in BEC is the only issue I could face if I see a failure. My truck isn't a race truck so I may just run a acc. battery pack anyway to be safer, thanks for the tip though.
Originally Posted by big greg View Post
if you are running 4s then just get a mm, and a fan, imo if you are only using 4s you really dont gain anything running a MMM, since both my MM have been bulletproof to me
I am only running 4s now but would like to go up a bit which is why I got the MMM as opposed to the MM. Ya know how these things go 4s is good now but 6s will be better in the future and so on.
Originally Posted by coolrunnings View Post
What can you afford budget wise? I run a 160.24 and a 160.24 for backup and then just last weekend I bought a 160.24 to back those up! And if those all fail I'll use one of my mgm 224.18 controls.
So I guess you like the 160.24 huh? If I had that ESC I would be using the MMM as the back-up maybe. Well that model may be a bit out of my budget but the 160.18 is looking like a potential winner, what do you think?
Thanks again to all,
Darion
