TruckBasher
TruckBasher's Avatar
09.02.2008, 10:10 AM
Made up a little diagram showing the UBEC hookup. It's a little different than most setups since the output of the UBEC must be fed back into the ESC, but that's about it. Oh, and I used the ESC input power solder points for the UBEC input.
Other mods done just for the record:
- Cut the case so the heatsink has better passive airflow
- To protect the circuits, I installed 1/8" thick foam pad strip along the motor and power wire solder points inside the case.
Here is BrianG's wiring diagram....only need to short is the switch wires as it doesnt do anything....
Oh and that photo from Joe was V2....mine is V2 also only a bit smaller....
EDITED:
ohh and dont forget we do it at our own risk
E-Slayer direct drive to diff
