david lamontagn
09.02.2008, 10:13 AM
Success!
Removed the components Patrick suggested and it works like a champ.
The MMM switch is useless now, switching it off did nothing. So I bridged the contacts at the PCB (did this after the pic above).
And now, I can use the Castle Link without any mods, nor do I need batteries hooked up to the ESC. I don't know if this mod makes anything run longer or better, but I feel better with my V1.
BrianG, on this pics, i can see the removed parts, the bridge on the switch wires, but were is the brown wire goes on the Rx????
And after the mod, i know you run an external BEC but did you remove the red wire in the Rx plug?????
Do you have to route the external BEC output wire to power the ESC????
Please i need clear expanation, and tell me if i can do this on the V2.
I'am french and sometimes i've somes difficulties with english explanations.
Thank you
