teknorc
09.04.2008, 02:56 AM
Originally Posted by rckcrwlr View Post
Had to do it...Build to follow....
Running the Techno Kit...
Will I need to lock the clutch or get a faster engaging one?
I did a test with a 3S LiPo and it took everything to get it to engage...plus no speed.
Will probably lock in 2nd...but not sure of the clutchbell deal.
Quick note on the clutch here. Depending on the motor, 3s may be under the RPM range for the clutch to fully engage properly. Make sure you are in the neighborhood of 30K total RPM runout (voltage * kv) or faster and you should have no issues.
Tekno RC - Performance Parts
