roweder
I got my MMM Combo!
roweder's Avatar
09.05.2008, 12:38 PM
Warm isnt so bad, but hot is. If you had a little pot (no, not that kind), you could adjust the speed of the fan, so it only blows gently and quietly when the power supply isnt in use, but turn it up to full power when it is.
what exactly is a pot? and I'm guessing that by little you mean small in size and not amount?
do you have a link?
In this case(meaning situation), I think warm could possibly be slightly bad, because the bottom of the unit inside is 1/4" away from the bottom of the case, and the bottom of the case has air wholes in it.
  Send a message via AIM to roweder
