roweder
I got my MMM Combo!
roweder's Avatar
09.05.2008, 11:17 PM
believe it or not... but today, I got, in the mail..... a working Xcelorin system for the speed-t!!!!!
i got to show the italian bikers staying at our house for the race tommorow how fast it is!
i had some problems with it that were my fault, first i noticed that the ESC's lights weren't on, it was because i hadn't turned it off and on again after i calibrated it to the transmitters, and then it kept turning off and on randomly and i found out that that was because i had plugged the connectors together just a tiny bit for the initial test run from my bedroom to my parents bedroom, and forgot to plug them in all the way, then later the connectors got stuck together and i still can't get them apart, but now I have deans on it. It's all good now I kind of couldn't believe it when it worked, this is the 5th xcelorin system that i have owned and the 4th that was replaced for free.
so, what you should do if you want an xcelorin system (they've got high quality features and the ones that work run great) is buy 5 and find the one that works and return the other 4, because as far as i know, out of every 5, 1 will work.
  Send a message via AIM to roweder
