traxxasrevony
09.06.2008, 10:09 PM
the mgt was super easy i just took my mmm 8xl out of my revo because i blew the tranny again. all i did was remove the nitro mount build aluminum plate that bolted to the chassis but i put small spacers under it to keep it directly off the chassis and driller 4 holes in it to bolt the flat part of the rcm revo mount to. then put the pinion on and away i went. i need a smaller gear though as i have motor temp problems. im going to buy a tekno electri clutch to run a cb on it because i have alot of them to work with. then im going to buy the tekno kit for the revo to run the clutch also to try and save the tranny some abuse and also get a 9 xl for the mgt and put the 8 back in the revo.
