jhautz
jhautz's Avatar
09.07.2008, 05:19 PM
OK so this V2 MMM gave me more problems to the point I couldn't get it to start up. I pulled it out and and I have been messing around with it cuz it will still start up occasionally and run for a bit before it stops. Very weird. Haven't heard of anyone else having this problem.
I started checking the BEC output voltage and when I flip the switch and it works it puts out around 6.2 volts from the BEC. When it doesn't boot up it only puts out between 2 and 3.2v randomly.
I am wondering if the BEC voltage was changed on the V2 back up to 6v from the 5.5v the V1 was supposed to be putting out. When I test the only functioning V1 I have it puts out 5.43v consistently, so this is in line with the original 5.5v spec that CC said.
Just wondering if anyone has a functioning V2 they could check the BEC output voltage on. I just found it a bit weird that it was putting out over the rated 5.5v. Of course its a messed up V2 so I have no idea.
I'm mostly just wondering if they changed the output voltage on the V2 to around 6v
If someone could check theirs I am very curiuos.
to make it...
or break it...
Silent...But Deadly
