09.08.2008, 02:48 PM
Other than the two disadvantages you noted, not that I can think of.
Most people grab power for the BEC right at the Deans connector, which can make wiring look a little messy. If you don't mind taking the ESC apart, you could solder those wires directly on the power input on the ESC. You can make wiring a bit cleaner that way.
