Originally Posted by JaySki
And up to 300AMPS in Burst (10 Second/1 duty cycle)
so.. again.. I am not out of spec..
You keep saying that but I posted how you were not. You used batteries that were not up to the task and a hot motor that without the proper airflow puts you way out of spec quickly. Without a data logger how can you be so sure you were in spec, how do you know you didn't have much higher spikes?
You also need to research ripple current as was suggested previously in regards to the batteries you used.
Again a fire is not a simple bec failure, it is caused by overload.
