JeffEmbracedDC
JeffEmbracedDC's Avatar
09.13.2008, 06:44 PM
Originally Posted by lind5 View Post
well mate its in a converted lst2 with a emaxx gearbox
using
1515 1.5d 2700 kv might change when i can afford it
mamba monster
spur 54 t mgt steel mod1
pinions hardend 16/17/18/19/20
proline 40 series wheels
proline mulcher tyres
was going to go 6s but been told to stick to 4s with this motor
Definitely a hot motor for that truck. Honestly, the only way you'll get it to work reliably with that motor is on 4s and you'll have to double up your packs in parallel which will double your maximum discharge rate.
Ideally you'd replace that motor with something closer to 1500kv run on 6s. But if you were stuck with that motor I suggest you run two 4s 5000mah 20-30c Zippy packs in Parallel ending up with a 4s2p configurating and 10,000mah. That would be about 250a you could pull from those batteries and honestly at that point you might have issues with your ESC. That's a lot of amps!
If you only used one battery it would be about 125a max and honestly you'd end up with bad performance and puffed lipo cells.
Your best bet by far is to get a 1515 or 1521 around 1500kv and go with 6s lipo.
I personally run Zippy packs and have had no issues.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
