Thread: E-Slayer Build
rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
09.14.2008, 11:44 AM
Now comes the electronics...
When you are running a nitro tranny you must use the mechanical brake and disable the ESC brake. Wiring is easy by using a "Y" Connector where the ESC and Brake Servo go in the two sides and you plug it into the Receiver Throttle Slot.
So I had this small ESC laying around so I figured I would use it on this project... :o
It is a little thing called a Mamba Monster Maxx (MMM)...check out these specs:
The only way to appreciate the size is to compare it. The first pic is the motor wire next to a servo wire. The second is a stock bullet plug and the one's that come with the MMM. These things are huge!!!!
It comes with a built in fan that when it is spooling up sounds like a turbine...
So she is all ready to go...just waiting on a 5s LiPo to get this puppy going...
Bought my Wife a Rock Garden :027:
