lutach
lutach's Avatar
09.14.2008, 02:35 PM
It won't work. For that ESC to work with a brushed motor it needs the appropriate software. I have that ESC that was sent as a test unit from Suppo (The manufacturer) and they keep everything simple, so it won't have the software I mentioned. and it won't work at all with a brushed motor. If you're on a budget and try it, it'll be costly as you spent the $$ on the motor and the batteries. If you go with the options I showed you, you'll spend a little more $$$, but it'll work.
