neweuser
neweuser's Avatar
09.16.2008, 01:28 PM
I would like to incorporate the FLM Tranny case. Extend the lower ends for the diff to fit and bore out the bearing holes to fit the larger bearings. I think Mike and Jamie could figure this out to fit a 1/8 center diff for the hot bodies. It would be a bolt right up I think. Same concept as the slipperential only utilizing the the tranny more so and encased. I think this would also need custom drive shafts to fit, they would have to be a bit shorter. The good thing about this way would be no figuring where to put a motor mount I would think. Too bad I suck as CAD, otherwise I would get one figured out.
