Dadx2mj
Dadx2mj's Avatar
09.16.2008, 10:02 PM
Originally Posted by jayjay283 View Post
Typical forum post. Your setup ? External factors, nothing, just 3 MM failed. out of the blue, just *poof*.. not your fault, nothing to do with the 8c lipos, no fan or your 11 year old unsupervised for hours running them. Ive had 3 TVs fail in the last year, should I mention I used a baseball bat to adjust the settings
Wow why so hostile? Why would you assume things so negative. I was simply stating my experience but since you wanna know I have been through this with Bernie and Thomas more than once and they both agree the set up is fine.
Rustler with FLM tranny case running on 6 cell nimh for first two that failed on 2s lipo for second. Motor has heat sink and ESC has Novak fan. There has never been a temp issue. First ESC failure was the switch ripping the wires right off the circuit board, next two just went poof.
Frankly I think I understand how Patrick feels now there are more than a few people here who simply like to just flame others and assume the worst.
Blindman Racing
Powered by Mamba 5700
