Thread: Batch 2 V2 MMM
DickyT
09.17.2008, 09:12 AM
Patrick,
Your PM box is full, so here is hoping you see this. I just read your post "Well, I think we agree with you. We are currently reworking the mold to give about an additional 1.5mm clearance by changing the size of the board supports and the case bottom. we are also adding 1mm of clearance for the fan. The case will be taller overall, but will help prevent issues from board flexing and fan collisions during extreme Gs...
Patrick"
I think it is great that you guys may have found an issue. When you have the new case design will we have to send our MMM's in for this new case? Or can we have the case sent to us? I've had mine open many times to check the fan wires, still ok on my v2 after 30 hours, but the foam pad is looking worse for the wear.
I think it would be great if we had the option to send the MMM in for you guys to do the case swap for those less inclined or the option to have one sent to us and return the old (or trash it) so that we do not experience anymore downtime. If you would like some real world testing of this new case I would be happy to oblige. I am rather rough on my gear, I am no racer, but an extreme basher
Thanks,
Richard
