Originally Posted by neweuser
Yeah, but is the cup the same diameter as the maximizer? Looking for something that can hold a 6 internal, yet bolt up to that gear.
I doubt that you will find that. Looks like traxxas uses the gear on the center diff as the cover.
When cowbody made the setup for the nitro revo he used a different gear, as he had it machined to mount to an adapter that acted as the diff cover.
My main issue with the traxxas design is that it uses the output shafts to hold the assembly up via the stock bearings. I plan to have the diff case and my adapter run on bearings, and the shafts will run inside the diff and the adapter, just like they do on an 1/8 scale diff. Should last longer and rotate true. Plus my design will have a 4 spider diff, not the 2 spider traxxas setup.
