neweuser
neweuser's Avatar
09.17.2008, 02:05 PM
If they would design a new case that was similar to the new emaxx/erevo case, make it so that it uses the same input shaft and idler, but has the lower area remade to accept a diff. It would have larger bearing areas to accomodate 8/x16 bearings, and would have custom made output shafts. They would have to either make a 33t gear, or mod the existing gear like I will. The only real difference would be the larger bearings. I am stuck using 8x12 bearings as the stock tranny case has 6x12mm bearings stock.
I plan to use ceramic bearings, best that I can find.
Exactly my idea. I sent the idea to Mike yesterday, no response as of yet. I hope he thinks about it.
